Up Topic Welding Industry / Technical Discussions / Brasing tube on plate
- By YVAN (*) Date 12-10-2003 20:35
Want to braze as many tube as possible on a base plate. Tube 5/8 dia. and 0.035 wall thickness, stainless or aluminum. Base plate stainless or carbon steel. Hole may be drilled in the base plate and furnace brazing may be used to braze the tube to the base plate.
We are looking for a supplier who have some experience with that kind of process.
