Up Topic Welding Industry / Technical Discussions / 5083 ALUMINUM PLATE WARPAGE
- - By EVWELDER (**) Date 12-13-2003 02:31
I have recently welded some 3/16 thick plate as covering on a project I'm working on.The problem is there is some conection plates on the inside welded to the plate that has caused a wavy effect on the outside looking at a straight run of this stuff. I clamped down the plate when welding and put as little of weld as possible with a 3/32 5183 rod but still recieved disstortion. Any tips on making the plate flat again the pieces are going to be powder coated I would like to stay away from any kind of bondo if possible.
Thanks
Parent - - By G.S.Crisi (****) Date 12-15-2003 18:59
On Welding Journal magazine (AWS' official magazine) of February, 2003, page 29, there's a comprehensive article on the subject.
Parent - - By EVWELDER (**) Date 12-16-2003 03:44
I do not have the welding journal for Febuary 2003 can you tell me what it states in the journal.
Thanks
Parent - - By G.S.Crisi (****) Date 12-16-2003 14:25
Let me know your mailing address and I'll send you a xerox copy of the article.
Parent - - By EVWELDER (**) Date 12-16-2003 17:26
MY MAILING ADRESS IS 2160 COMMERCE MIDLAND TX. 79703 ATTN:EDDIE V.
THANKS FOR YOUR HELP.
Parent - - By G.S.Crisi (****) Date 12-16-2003 19:10
Post offices are already closed for today. I'll mail the copy tomorrow (wednesday, december 17) morning. It'll take 4-6 days to reach you.
I don't want to scan it up and send it by electronic mail because there are several drawings in the article, and they loose quality when scanned.
Parent - By EVWELDER (**) Date 12-17-2003 02:27
THANK YOU FOR YOUR HELP I'LL BE WATCHING OUT FOR IT.
