Hi Aircraft, Larry L!!!
You're right Aircraft when it comes to a true square wave power source such as Larry L's machine but, with a sinosudial wave type power source like for the older conventional power sources; the high frequency setting @ continuous is needed to maintain or stabilize the arc so that the cleaning action can be accomplished and maintained. For more precise control of maintaining the AC arc without a superimposed HF current, manufacturers came out with (approximate square wave form) early PCB models - followed by microprocessor based progammable square wave power sources yet some sort of ionization of the gas across the air gap was still required in order to start and stabilize the arc without making contact with the metal first... This is where capacitor discharging was first used and then later replaced with HF start and continuous as found in the more recent conventional power sources... Inverters achieve this with greater efficiency in a variety of ways that have rendered the conventional power sources "Obsolete"!!! Well maybe not yet but, it's inevitable!!!
Could you imagine if computers took as long to become obsolete???
When the first generation of inverter type power sources came out they were at first DC output only power sources which were'nt suitable for thinner aluminum until the twin inverter design which enabled polarity switching. Hence, a form of variable polarity became available...
So yes, Aircraft you are correct in mentioning that HF does'nt actually do the cleaning with either a conventional or inverter type AC/DC power source.
The cleaning action is from the current @ the positive or reverse polarity side of either the sinosudial or square wave half cycle. This half cycle current is much more stable in the "True" square wave form and @ a higher frequency (150hz max for Larry's power source) AC welding current output (not to be confused with pulse-frequency) because it takes relatively speaking, much less (almost immeasurable with Miller) time for the AC current to go from one half cycle to the other (do not include the amount of time the current stays in each 1/2 hz @ peak polarity % for this can be adjusted with sloping and or pulsing) than it does with a sinosudial wave where there is greater period of time of thermal electron emission decay as opposed to virtually no time with a "true" square wave form without sloping... As the current passes close to (arc extinction zone) and through "ZERO" (in order to complete a full cycle or hertz, this "arc extinction" zone is found on both halves of each cycle in a sinosudial wave) the arc is unstable (@50hz in other countries - 60hz over here) so in reality, when the AC current in a sinosudial wave is used without HF continuous frequency; The cleaning action is'nt consistent because the arc itself is'nt stable... Older conventional GTAW power sources that produced sinosudial wave forms needed continuous HF in order to maintain the cleaning action that was intitially achieved by the current being @ it's peak% (usually balanced or 50%) in the positive (RP) half of each cycle. Otherwise the arc would become unstable resulting in poor weld quality.
The opposite is the case with programmable true square wave output current whereby thermal electron emission decay & the so called "arc extinction" zone between each 1/2 cycle is virtually eliminated and as the case with progammable square wave forming (customizing the % of polarity in each half cycle and the amount of time the current stays in each polarity before the beginning of the next 1/2 cycle) coupled with (pulsing) control of output frequency - customized variable polarity pulsed welding current output can be achieved. This is limited by how much control the operator has with both the wave "shaping" or forming and controlling the amount of frequency that is available which varies between manufacturers of welding power sources...
NASA had concluded in their initial research that welding current with very little time in electrode positive or reverse polarity would improve the welding of aluminum. The reverse polarity or electrode positive 1/2 cycle is required for ionic cleaning, but the maximium work is performed by the straight polarity 1/2 cycle so longer time is needed in the electrode negative 1/2 cycle... This is not to be confused with the percentage of straight and reverse polarity current amounts found in balanced and unbalanced square wave forms
A special variable polarity power source with a square wave output was designed for GTAW & PAW of high strength aluminum. This power source, which provides a waveform with a short time period of electrode positive (1/2) cycle and a long time period in the electrode negative (1/2) cycle, was in effect 2 power sources - one with straight polarity and one with reverse polarity connected by means of a high speed electronic switch. This is an SCR type of power source with extremely fast switching and was used to PAW 1/2" thick aluminum alloy with "keyholing" in one pass that would produce "Water Clear" X-ray quality welds!!! This was an automated application called Variable Polarity Plasma Arc Welding with Pulsing or VPPAW-P used in the construction of the external fuel tanks for the space shuttle fleet...
I believe they're using updated equipment today...May our heroes Rest In Peace!!!
Twin type or even more sophisticated Inverters with computer controlled switching can achieve the same so long as the electronics are designed to enable the operator to control and customize the amount of time period the welding current output is in either reverse or in straight polarity coupled with programmable wave forming, adaquate storage for a large amount of customizable weld schedules and a far greater range in frequency output control than what is currently available on the market at an affordable price... Only some of the newer orbital welding equipment power sources can do this and they're far more expensive than what Larry L's got!!! That Miller Aerowave is on paper as close as it gets to a GTAW power source with all the bells and whistles and yet, I only used one welding Duplex SS so, I do'nt know what it can do with aluminum. Hey, the Dynasty 300 with pulsing (higher AC frequency limit than the Thermal Arc model) is no slouch either!!!
I guess I was thinking in a "nostalgic" frame of mind within my initial replies to Larry L without considering the power source he's using...
I apologize for any confusion there folks!!!
I ca'nt help with the type of tungsten but I'm sure you'll find what works for you best... What about a 65-70% electrode (-) and 30-35% electrode (+) wave balance setting with an increased pulse frequency not to be confused with the AC frequency and or are you using any up and down sloping??? Btw, Lawrence (not to be confused with Larry L.) - what do you mean by cathodic etch? Aircraft?
I believe that the black color coded W (lanthanated) alloy will work best with Larry L's balance setting but then, it's just my personal preference... Good Luck!!!
SSBN727 Run Silent... Run Deep!!!
P.S. Happy Holidays to all!!!
