Thank you for your response and direction to the note (Note 7, pg. 72). The welding process is SMAW and the Joint Designation is BTC-P10 and this note still applies.
"7. If fillet welds are use...to reinforce...groove welds in corner and T-joints, these shall be equal to T1/4, but need not exceed 3/8 in."
I still have an unresolved issue with this note, in that it specifically states a size of fillet reinforcement of T1/4. I know what T1 is, and I understand as T1/4 exceeds 3/8", the fillet reinforcement need not.
However, I need more build out than T1/4 to reach my effective width size for my desired weld strength. Am I restricted to T1/4? This note does not state T1/4 as a max or min., rather as 'shall be equal to'.
So, if I were to build up a flare bevel weld on a 1/4"(.233") wall rectangular tube with a 1/4" fillet and use the shortest distance from the face of build up back to the start of the flare bevel to measure my effective width, and then use this width to calculate my weld strength-it sounds like I would be at variance with the code. (Obviously a 1/4" build out is greater than .233/4.=.05825)
If I were to need more weld strength for this joint and one that is still pre-qualified weld, is my only solution thickening the tube wall? Thus flare bevel weld size and fillet reinforcement size is larger. Or can I build out the fillet reinforcement greater than T1/4 and calculate the effective width?...........Which personally is what I would, of course, prefer.
Anyone up to further enlightening this greenhorn?
