When I weld on a block of A-2, I draw it back with overnight cooldown in furnace, before striking an arc. Preheating just does not always work.
Your preheat seems a bit low. I would have gone to 750-850 degF minimum, just to be sure. Just personal experience talking here.
Be sure to cover everything except exactly where you are welding.
Also, I would have started at the inside, and worked my way to the outside. This may have not been an absolute requirement if preheat was high enough, but the shape of the weldment often require this. This seems to work for me.
Preheat and interpass temps must be close. +/- 25 degF would be a good mark to shoot at, but +/- 50 degF would be the absolute max.
Remember, A2 is an air hardening steel. It will change hardness when a temp differential (base metal to weld metal) occurs. As long as it is in air, hopefully still air. Another point to consider-your hotplate probably keeps the bottom of the weldment at a good temp-but there is surely a temp differential from the bottom to the top. This temp differential is a killer on tool steels.
You also don't mention how the weldment was handled after welding-
was there a slow cool in an oven...was there insulation wrapped around it...and so on. This is really important.
312 is always a good choice when welding these types of steels.
The one problem is, 312, being an austenitic type stainless, will not respond to heat treatment,period.Very ductile and a high ferrite # seem to minimise cracking with this alloy, but unwise use can affect the integrity of the weldment.
If a tool steel weldment is to be re-heat treated for full strength, 312 isn't the best choice for underlayment. The overlay (even if it is A2) will always be in jeopardy. It will be hard, but the interface will not be.
I've had luck using 410 stainless (also an air hardening steel) on these A2 weldments, but this is something you'll have to try and evaluate.
Additionally, I don't think I would try the taper you mention-the depth to width ratio.
Put on what you can, reliably, and let the machinists or grinders take care of the final profile. Thin deposits of tool steel will crack-undercutting your weldment might be well advised to keep a decent amount (1/8-3/16) of buildup on your part.
All in all, I think a higher preheat and close interpass temp monitoring should solve your problem.
Letus know how you make out!!
Good Luck
brande
