Hi Ali
Generally you do not need to perform any post weld heat treatment, (PWHT) because the Nb added to the base metal and filler will tend to stabilize the weld and HAZ. As with all Austenitic alloys, you just need to weld it relatively cold, with a relatively low heat input.
Generally the H grades are used where high temperature strength properties are required. You will therefore find that often these alloys operate within the sensitization range in any case, so a PWHT will not deliver any lasting benefits, even if it did reduce the weld sensitization.
This sort of information is not really given in "standards", but I may refer to ASME 8 Div 1, that shows that PWHT is not a requirement for any of the P8 materials. (347H is a P8 Gr1 material)
I hope this helps.
Niekie Jooste
Fabristruct Solutions
