Up Topic Welding Industry / Technical Discussions / Flux cored pipe
- - By YVAN (*) Date 01-05-2004 14:27
We need to manufacture pipe with flux inside, similar to flux cored wire. Pipe diameter 0.250 inch. Pipe wall thickness 0.010 inch. Flux size range from 35 to 325 mesh. Pipe shall hold inside pressure of about 350 psi. Base metal should be 316L stainless steel.
Parent - By GRoberts (***) Date 01-05-2004 15:30
I have heard about a company that produces seamless flux core wire by starting with a flux filled pipe. Try searching for filler metal manufacturers that make seamless wire and they may be able to help you.
