I've used the same basic idea years ago. We all would run rosebuds under steel tables, in special "heat sinks" of steel, and in empty trash barrels. The shop had no heat, and when steel was coming in one end and being loaded out on the other, the wind would whistle through the place. None of our set-ups were ever "sanctioned" by management and they had to enforce some new rules after one guy nearly blew his head off.
(true story coming up, names withheld to protect the incompetent)
The guy had a hole in the bottom of a 55 gal drum, put a rosebud in the hole, and put a plate over the top of it. It did throw quite a bit of heat.
Seems that he was feeling extra "efficient" one evening and shut off the torch at the supply valves instead of at the torch. He didn't want to bend down to get it.
The next morning, he turned the supply valves back on and went chatting for a few minutes while he got his hard hat on and tool box opened. He then pulled the torch out, lit it, and stuck it back in the hole. The resulting explosion blew the plate past his face, launched his hard hat somewhere, burned off all his facial hair, and shook the dust off the rafters in the entire building. I observed him staggering towards the men's room, babbling incoherently. No, wait! He did that every morning for the first 2 hours! But this time he really DID need to use the facilities.
Thankfully, he wasn't hurt.
Just be careful, to anyone who tries the same things.
Chet
