Bench a little to pass FPI ;) works all the time....
Seriously, this is a power density adjustment issue. If you cannot adjust the power than your are stuck with more rework ( hand blend and re inspection) to meet your spec.
If you can change the spot diameter then work on a more gradual change in focus point by a combination of travel speed variation (increase) and change (pull back) on stand off distance.
These are all minor tweaks to reduce the net effect of the beam on the surface of the part.
Sorry to put it this way but you need to be in control of your process. By what ever means it takes to do it right the first time, it is so much cheaper in the long run even if you hire a off line programmer to fix your program.
