Well, after a final consultation with one of the Thermal Arc consultants, I decided to order the parts to change the 14-pin connector plug of my RCCS-14 hand remote control to an 8-pin one. I found all of the parts at Allied Electronics. The total cost for the 8-pin plug (Allied #512-1116), pins (#512-9520) and insertion tool (#512-0470) including sales tax and shipping will come to a little over $65. Thermal Arc does make an adapter cord (T/A #10-4003). It sells for $91, which is astounding for a short piece of wire with plugs on both ends. Another option I could have chosen was to auction off the RCCS-14 since it appears to be a new unit, and, purchase a T/A hand control. However, I decided, however, that I preferred using the Miller RCCS-14 over the T/A one.
Brande, after I finish this modification, I'll have no need for most of the solder-on cup, DF-20 pins, remaining from the 100 pack that I had to purchase. Can I send you the 80+ that I won't need? Otherwise they would sit around and gather dust in my workshop for the next 10 or more years.
Dee, sorry for the mistaken gender identity.
LarryL,
Thanks for posting the update on your project. Always like to hear how a person finds ways to fix things and how they went about it.
John Wright
Do you wnt to sell your 14 pin connector and some pins?
I'm going to convert a T/A foot controler to a Miller 14 pin.
As soon as I receive the T/A foot controller.
Any suggestions on this?
thanks
Doug
No, but I'll be willing to give it to you along with about 20 pins if you're willing to pay the FedEx shipping which may come to $4 or $5. You have to understand that it may require a special tool to extract the existing pins from my old plug and insert the new ones - since I'm going to cut off the present wire to it just outside the plug. I don't have the tool to open up this 14-pin plug (it looks like the inner cylinder unscrews from the outer housing). Brande may have a suggestion on what is needed to take it apart. As I mentioned, the pins I ordered have a solder-cup type connection. I didn't buy the less-expensive, crimp-type pins because those require a special crimping tool. Another shocker: the cheapest crimping tool (Allied Electronics catalog) costs about $150, and, the more expensive one costs $500+ (perhaps this tool is made of 14K gold?). I'll be able to confirm my offer to you next week after my order arrives from Allied Electronics.
Solder is the more reliable connection anyway.
Some pins can be extracted using a brass ball point pen refill as the tool.
Bill
DEA, I compared the Miller's and Thermal Arc's connector plugs by putting them alongside each other.this morning. The Miller's pins are larger in diameter and longer than the Thermal Arc's pins. Therefore, the DF-20 pins that I will have on hand will not be of any use to you. You can still have my 14-pin Miller plug, however, if you want it.
I spent a couple of hours this afternoon fabricating from scrap steel a cylindrical type of spanner wrench for taking apart a 14-pin plug (With a little bit of silver or gold plating on it, it should retail for $250 ;<D ). I don't know what the commercial wrench looks like but mine worked fine and enabled me to unscrew the connector. The existing pins in it appear to me to be the crimp style. There are no markings on the 14-pin plug so I can't determine what kind of replacement, solder-cup pins it will take. Brande probably can provide you with this information. You can have my homemade cylindrical spanner tool also since I will have no further use for it after modifying my hand remote control.
Larry
Yes,I'm interested in the 14 pin connector
Leave a little bit of the pig tail and maybe I can splice into it
Let me know the details
Thanks
Doug
I also found some connectors at
www.ssccontrols.com
By DEA
Date 01-24-2004 15:32
The foot cont. is a Thermadyne
Sorry I posted it as a Thermal arc But I guess thats the same outfit
Doug
Larry,
No sweat... I wanted to use "D" as my handle, but it was too short and so came the result. (it was the name by which my friends sometimes knew me)
I tried to be funny about it and poke some fun- I didnt mean anything other than that by my comments.
d
I'll take them off your hands, as I do a good deal of plug work.
Let me know how much you want for these buggers, and I will send my address. Email direct if time is an issue.
I'm glad you got your problem worked out, and I hope my advice played some very small part.
Feels really good when you beat the factory out of a few bucks, doesn't it??
Good Luck
brande
Brande, just mail me your address offline and I'll mail you the pins when I finish putting on the new connector. Allied Electronics only sent me half of an 8-pin connector so I can't work on it until I receive the other half sometime later this week. Your advice has been very helpful and it more than compensated me for the cost of the excess pins.
There were mixed opinions on the Hobart welding forum about whether just changing the plug to an 8-pin one would make this Miller hand remote control work well with a Thermal Arc welder - because the Miller remotes have a 1K potentiometer and the Thermal Arcs have a 5K one. A welding tech on that forum indicated that the remote would be super sensitive. However, the Thermal Arc engineer indicated that it would be useable. I have all the parts ordered so I feel that I'm committed to trying this modification.
Shouldn't be a big deal-I've run Miller controls on Thermal Arc equipment with little problem.
Good Luck
brande
Larry,
I despise people who use a forum to bash businesses they dont like... I gotta give you a heads-up on this, though.
I stopped dealing with Allied because they "back-ordered" a small part I needed, a very small, 10 cent pushbutton switch which was the whole purpose for putting up a fifty dollar minimum order. After some weeks of waiting, with a paying customer awaiting a repair on the other end of this botched transaction, Allied tells me I have to reorder - in order to do so another fifty dollar minimum was required.
After years of satisfactory service no less. They were bought by a group called in-one I think which ruined them. A different in-one company hung up an extruder repair on me for four weeks on a part they said they had, which they never did get.
I'd like to hear they have their act together again; I used to like Allied till they went sour on me, and I'd like to use them again if it's practical for me.
Don't let the transaction get away from you.
d
Dee, I wasn't trying to bash Allied Electronics. Not having built or repaired any electronic equipment recently, I haven't dealt with any electronics suppliers for a long, long time. I dealt with Allied because I thought that its online catalog was the easiest of all to navigate. I couldn't determine, however, from the item's online image or description whether or not the connector plug included the cable clamp. Therefore I phoned and asked a sales rep if it included the clamp. She thought it did and therefore I placed my order. When it arrived last Friday, I found that the plug didn't have the clamp end. I phoned Allied again and explained my problem as I didn't want to have to place a $25 minimum order just to get this $3 item. This different sales rep said that he would send it to me as a sample - even though I offered to pay for it. They made good on it even though it meant a few more days delay in getting the parts I need to modify my hand remote control.
Maybe Allied has been trying to improve their image since you last dealt with them?
