Power plants are notorious for magnetism problems,especially when welding in/on the turbine hall or pipes that have been mechanically machined.? When I was welding these type of joints, I would get another welding machine and wrap the cables around the weld joint (5 to 8 times), adjacent to the weld, in an opposing fashion regards polarity-each side of the joint, then join the cable ends together! creating,in effect, a direct short!,then turning on and increasing the amps till the magnetism disappeared
Worked for me,but I know of no 'Standard/Code' that allowed for this!
