Jon,
You are correct...you will get flack :)
I am curious as to how you arive at that conclusion... here's why I think I disagree...
GMAW machines are contraptions when compared to the simplicity of stick. You can worry about wire selection, adjusting feed mechinisms, feed settings, voltage settings, stick-out, gas mix & flow rate, feed angle, travel speed, and various other technique issues. SMAW often requires merely filler selection and amp adjustment, which permits a bit more concentration on technique when welds are not testing well.
Give a newbie an improperly proportioned (mislabeled) mix and he may never figure out how to weld with that piece of equipment; there are simply too many variables to be able to solve problems efficiently, particularly if you are learning on your own.
I found the hardest part of SMAW was to strike the arc.
The friendly folks at the looney bin said I'm ok now, so I know I'm not nuts... perhaps I was just lucky?
(Once I learned to start the arc well, I figured out how to cut the rods down to where I could use them more comfortably... they are too darn long when they're new.)
On a side point, those wire reels cost quite a few bucks more to build a selection of, compared to a variety of rods of various sizes and alloy.
Everyone says GMAW is easier to learn (well, it is a popular opinion if not unanimous) however I don't accept it based both on face evidence, as well as my personal experience. Folks who teach it may know something I don't, and, to be fair, I already had some welding experience before picking up my first stick electrode.
I am not ridiculing contrary opinion when I say, in all honesty, I am curious as to how others base their opinion.
d
Fusion and penetration will be more insured with smaw done by a beginer as compared to gmaw. I have put down some welds in hast on rusty steel with my gmaw, and was quite surprised when they cleanly peeled off the piece. A good stick weld with a general purpose rod is hard to do that with, even though it may look horrible.
Dee, my comments re GMAW vs. SMAW were largely based around the skill factor. You are correct in that GMAW is a contraption when compared to SMAW however, learning proper settings especially with a little "book learning" are, in my personal opinion, much easier than running 50 or 100 pounds of rod in order to learn the basics of proper technique, manipulation, etc. I'm sure it's just a a matter of personal preference but learning GMAW techniques were for me lightyears simpler than learning the SMAW techniques. If Dark Theater was going into the welding profession, of course I would be the first to jump on board and recommend SMAW as a beginning method. With regard to budget constraints, I agree a SMAW would be much less expensive in the short term. My concerns re SMAW are for flexibilty; i.e., what if Dark Theater has a need to weld aluminum at some point? I know, I know, they make aluminum electrodes, but no one I've ever spoken with has had much luck with SMAW welding aluminum. Okay.... there's another nickels worth on top of my two cents! :)
Jon,
Your opinion needn't agree with mine for me to respect it.
My experience with the two processes was just the opposite, however, and one of the little things I always wanted to do was to figure out how "those folks could say something like that" regarding GMAW's learning curve... the system is much more complex, which presented some difficulty until I could get it right.
...now I will be off exploring the psychology behind the difference as it relates to the apptitude we're describing. (no, I am NOT saying you're nuts in a $2.00 vocabulary)
I appreciate you taking the time to share those details, although I still hold to my original opinion..
d
Ok here's my two cents,
SMAW with a 7024 drag rod on mild steel. It just doesn't get any easier than that. 7024 will look and perform nicely with minimal experience and doesn't require a rod oven. Move on to an F-4 rod after the guy gets some experience with making nice welds. "Most" things can be welded in a 1F or 2F position without turning the world upside down. With GMAW, I'll admit the trigger is very easy to squeeze and make fire fly, but the degree of success really depends on more variables as has been stated already.
John Wright
John,
I think it's great you thought to mention those details to help Darktheater along, and I hope he sees it in case he's buying from a catalog or the like...
Probably, as you alluded, the difference we're discussing has much to do with the individual's expectations for the welds they're producing. Beauty may be skin deep; performance is my criteria for rejection where cosmetics rarely offset physical properties. I'm lucky I never had much difficulty making molten metal do what I want... or perhaps time flies when you're having fun, I dunno. It's what floats my boat.
I can't think of anything anybody left out. I hope "theDarkman" is still lurking out there and drops back in with a comment or question.
d
Dee, I have an enormous respect for nearly everyones opinion in here (including yours!) so no need to worry about that. John Wright's points are also well taken. I guess it's simply a matter of personal preference and our own individual experiences.
