The AWS B2.1 (Table 2.1) specification requires additional testing to that required by ASME Section IX. You noted in your initial post your PQR was qualified to Section IX. Performance qualification to D17.1 requires eye exams for the welders (4.2.1).
1.) What type of weld classification does the project requirements specify for the D17.1 (A, B or C)?
2.) Which material group does the project requirements specify (Group IA, IB, IIA, IIB, etc.)?
3.) What material format is used (tube or sheet)?
I recommend getting your hands on copies of the AWS B2.1:2000 and D17.1:2001 specifications. My guess is you get to re-qualify the procedure and the welders.
