Our vendor has been wrapping a copper tube around the wire, but we are getting upredictable results with the strength of the weld. It seems to me that the gauge of the wire and thickness of the contact might make it difficult to get a good weld. The electrodes of the spotter are hitting the top of the copper tube and the back of the contact. There are 4 material boundaries in between the electrodes, and I am concerned that the copper tube is not getting enough juice to make a connection that can stand up to a little pushing and pulling in the field. I realize that our vendor's welding process, machinery, and general willingness to do a good job has a lot to do with my problem, but I have also been told that welding the wire directly to the contact is more reliable.
I will check out your suggestion for the brazing. Thanks!
