Alot of good advice already given, I will add that a E7024, in addition to the 6013, is a nice "drag" rod to start out on and like Bill stated, keep the arc short. These "drag" rods are just as the name states, drag it along the joint. The flux on the rod will burn away and will keep the arc the correct length for you. With these rods you'll gain some confidence and feel like you have that tiger by the tail. However, after you get comfortable with those type rods move on and try a E7018 or the like and it will humble you and feel like it has a magnet in the end of the rod that will stick to the base metal. With these rods it takes more patience to work and get the rod started and then you must adjust the arc length to keep it burning. But practice, practice, and practice some more.
John Wright
