I am going to throw my 2 cents worth into this thread....obviously, this is just my opinion, but i think that is what you are looking for....the 180 is a great machine. it will handle aluminum, stainless, mild, chrome moly, etc... the limit to this machine is the thickness of aluminum (or even steel for that matter) that you can effectively glue together. the 200 DX is a fabulous machine. I have used this machine a number of times on aluminum building oil tanks, on chrome moly building frames and engine mounts, etc... the ability to adjust the frequency and wave balance on this machine make it the cadillac (or mercedes, or bmw, or whatever your preference) of all the small inverter tig welders for aluminum. I have used the Lincoln 205 and it pales in comparison to the miller. by far, and this is just my opinion of course, the 200 DX is the machine that everyone that wants to weld should own. The difference in price is fairly minimal when you look at what this machine will do.
have fun.
If the machine can run 1/8" rod and has a reasonable duty cycle, you can weld virtually any thickness. My father-in-law was an ironworker welding oil platforms together in Cook Inlet using 1/8" rod (2" thick metal! Lots of passes.) The limiting factor will be aluminum TIG.
