Hi Bill!
There's no doubt that you'll get some good advice here with respect to the GMAW process...
However, if you want to get some answers to your specific situation then go visit this site: http://www.weldreality.com
When you enter the site, click on the link "weld product questions" and describe your situation to Ed Craig himself.
Ed will definitely set you straight but he may push his training materials on you which btw is'nt a bad idea to purchase anyway (prices are reasonable considering the wealth of knowledge inside)...
Post your query verbatim in Ed's site and you'll get an answer usually the next day.
I personally have to agree with H. Dibben on his advice to switch to spray or flux cored. As far as globular transfer is concerned; you might as well "stick" weld because that is the type of metal transfer in SMAW!
100% CO2 short arc is definitely going to give you more penetration because it's a reactive gas (hotter arc plasma) as opposed to a 75/25 argon/ CO2 mix which is mostly inert and that's why you have to set your welding parameters out of the true short arc range into globular transfer but will it be sufficient to eliminate LOF especially on the thicker part - is questionable. Preheating the thicker part will help also...
GRoberts and Tim Gary's advice is also excellent even though Tim's advice relates to a groove instead of a fillet weld.
Bottom line is to visit Ed's site because in my opinion he knows more about GMAW/FCAW processes and weld process training than anyone else in the business as you'll find out for yourself!
SSBN727 Run Silent... Run Deep!!!
