What are the transition points, namely volts and amps, between shortcircuit, globular and spray transfer modes. Is there written data on this? Thanks for the help.
Dont believe its quit that simple. Depends on alot of things i.e. gas mixture, wire type, wire size....ect. If you have a particular wire in mind you could probally contact the manufacture and get an approximation from them.
