Up Topic Welding Industry / Technical Discussions / silicon bronze tig??
- - By jdove55 (*) Date 01-31-2004 20:09
What is silicon bronze filler using the tig process used for?? Is it for welding castiron??
Parent - By MBSims (****) Date 01-31-2004 20:55
ERCuSi-A is commonly used for GTAW on sheet metal. It's OK for HVAC, but not for auto body work since you can't paint over it very well. I have also used it occasionally on brass fittings with success.
Parent - By sdcwi (*) Date 02-01-2004 17:51
A friend of mine just showed me some very nice tig welds joining stainless steel to galvanized sheet metal using silicon bronze filler wire.
Parent - - By GRoberts (***) Date 02-02-2004 06:07
It can be used for a variety of base metals, but is normally used for brazing, including GTA brazing, so the base metal shouldn't be melted.
Parent - By jer (**) Date 02-06-2004 03:52
Silicon bronze works well on galvanized sheet metal, can also use on copper and bronze.
Parent - By 49DegreesNorth (**) Date 02-02-2004 21:27
I can be used for bronze, too!
I accidentally welded up a rebar trellis with silicon bronze filler. Still holding up, six months later...
Chris
Parent - By brande (***) Date 02-07-2004 07:15
If you can get away from the hype-you'll have much better luck with aluminum bronze, A2.
The aluminum bronze is much more forgiving, more ductile, and has many more applications.
It does not centerline crack like si-bronze and can join most any alloy out there. No hot-shortness on aluminum bronze A2.
To be sure, si-bronze is somewhat cheaper, but I think you'll find better results with aluminum bronze A2.
This alloy has saved my pudgy pink behind more times than I can remember.
Also runs DC- or AC, if tig welding!!
Good Luck
brande
