Out-of-position issues with pipe may make spray impractical or impossible to actually utilize. You have a "cold" mixed gas that will minimize burn-through problems but presents some fusion issues in short-arc due to low arc energy and narrow penetration profile. I agree with sparx in general and specifically about c17; I use a c12 mix, but the filler you use will be also be an issue with the final result; stick to the 035 I believe... lots of data here:
http://www.weldreality.com
as you are probably aware, the more CO2 in the mix or the larger the electrode diameter, the more energy in the weld & the more risk of burn-through on thin stock and the faster you need to travel... if you can limit your weld to flat or vdown you might attain a potential in the realm an inch of weld (not filler wire speed) per SECOND in spray... c8 might be good for that but as you will see may slow down your rate of production by several inches per yard..
