Be very careful there!
We do a lot of boom repairs. We get the replacement tubes cut to fit directly from the boom manufacturer and follow their welding instructions to the letter, including NDE. Having a long history with those manufacturers, as long as we do as they indicate, they will maintain certification for the boom section.
A few times, we have increased the capacity of a boom by adding material to it. Again, all is per instructions but in those cases the manufacturer sends a rep to inspect and test everything before they certify the boom.
Key points to watch for, DO NOT replace boom tubes with A53 pipe. That is NOT what they are made of, they are high tensile strength materials. Welding on our booms is NOT done with 70K tensile strength electrodes. We have used 80K, 90K, 100K, and 120K all depending on the particular boom and welding instructions. Do not heat straighten anything.
There is some redundancy designed into the boom for safety. Maybe one lacing might not cause a problem (but maybe it will). But having made repairs in the past, at what point will the straw break your camel's back? I suggest someone should contact the manufacturer for guidance.
Chet Guilford
Chet's reply is right on the money, espically the involvement of the manufacturer regarding repair procedures, upgrades & modifications, inspections etc. Most manufactures will also assist you in development of your daily, weekly or monthly inspections as well. Hook and rigging manufactures (like Crosby) even have online forms you can download for this purpose.
That paper trail, including instructions from the mfg. and papers on the welder to weld the type material involved are essential to maintaining certification of the boom. Any shortcuts may leave you with all of the liability...from now on.
Andy
