From your description you have a standard bevel groove weld (since only one of the joining members has the bevel. This is opposed to a V groove or a square groove). This type of joint is typical. As was stated above several backgouge methods may be used and I also prefer an air arc. At any rate, once properly gouged the root side of the joint will be more of a U shape and ready for a back weld.
I guess the use of a backing bar is out of the question?
I was just in question as to whether the other side (root) of this weld is accessible. If your design allows for the change to a backing bar vs the backgouge, it would make it easier to weld without the welder being in a confined space, which brings up a whole new set of rules per OSHA.
just a thought to consider,
John Wright
Just to add to the good counsel you've already gotten, I usually like to weld inside the duct work first and backgouge the outside. Air arc is very loud, smoky, and sparks can come around and "hit you in the back of the head".
To clarify the definition of backgouge, A3.0 does not say how the metal is to be removed, so air-arc, grinder, milling machine, hand file,... whatever works without causing problems, is acceptable. I added that because I have had some people tell me that 'backgouge' means air-arc only.
Also, whenever I see 'backgouge' on a welding symbol, I know the designer wants full penetration welds, and that usually the designer is open to alternative grooves as long as we can assure full-pen.
Chet Guilford
