Dagwood:
A-335 is piping material. Have you had a look into the applicable ASME B31 Code (B31.1, B31.3 etc.)? The information you're looking for must be there, unless you're using it as a vessel nozzle, in which case ASME VIII applies.
Unless you are welding P91 to a different material, the normal filler metal (matches creep strength and chemical analysis) is E9015-B9 or ER90S-B9. There are also a couple manufacturers who make a FCAW electrode for this material. I'm not at a place where I can review the temperatures at the moment, but there should be plenty of others that can help there.
