Be warned. If you up grade to the NA-5 you may wind up buying new power sources. The NA- 5 has to maintain a +/_ .5 voltage.
You may be just fine, our primary power source created problems due spikes caused by other equipment in our shop.
The new lincoln power packs control the voltage much finer.
