At work we are building some 12ft. long arcs made out of 1/8 alum. We are making 3 corner to corner joint welds in either the 1f or 2f position. We are running 3/64 (.047) 5356 wire using straight argon as shielding gas. My problem is getting the machine set so that there is not too much material on the joint. Everything gets ground after welding, so the smoother I make the weld the easier to grind. I started out using pulse mig, but switched to regular short arc mig, seems to run better and easier to fine tune. I still can't get it set where I am happy with it. I turn up the amperage and burn through, but still have too much build up. Turn it down and of coarse more build up. I am running about 13.3 volts and 330 ipm, seems to run the best there, but still a lot to grind. I programed a start voltage quite a bit higher to prevent the heavy build up prior to the wire getting warm. That seemed to work ok. The only thing I can think of is that the wire size is too large, but I don't think changing it is an option. We are unable to weld downhill due to the size of the parts. Any suggestions??? Or do I just need to grind away!!! Thanks
