Using Table 6.1.9, published in "Marks Standard Handbook for Mechanical Engineers, 10th edition, here are some numbers that may help:
Aluminum has a density of approximately 175 lb/cubic feet
Magnesium has a density of 111 lb/cubic feet
Cut equal size pieces from the material you are interested in, and from a piece you know to be aluminum. If the weights are equal (or very close) you may assume the material is aluminum. If magnesium, the piece will be about 2/3 the weight of the aluminum piece.
I hope this helps. If someone has a better method, I would be interested in knowing it.
Charles Hall
Aluminum's GTAW arc should be white. Magnesium should be green. If you have zinc die cast (pot metal, white metal) that should be a violet/purple arc. Now the only thing to determine is the alloy. Aluminum with high amount of magnesium will show a greener arc than white.
