Up Topic Welding Industry / Technical Discussions / Preventing or Containing Weld Splatter
- - By Hi-lex Date 02-26-2004 15:03
Hello everyone, I am an Engineer, but not a welder. I am trying to help my manufacturing plant find a solution to our weld splatter problem. We currently weld galvanized stamped brackets to a galvanized roll formed rail which is a sliding surface. Splatter is deposited onto the rail during welding and causes problems for our sliding application. They have tried adjusting the welder settings to reduce splatter, but the weld strength is not sufficient. I would appreciate advice for preventing or containing the splatter during welding. Thank you.
Parent - By jwright650 (*****) Date 02-26-2004 15:20
Remove the galvanized coating before welding. Just in the weld joints.
John Wright
Parent - - By kam (**) Date 02-26-2004 15:26
Hi Hi
We might need alittle further info to better assist you. What is the material thickness you are welding? Maybe list current parameters...i.e volts, amps, wire type, gas...ect. Are these hand welds or is it on an automated system.
Is you setup capable of pulse? If so that would be something I would look into. Also check your torch angles. Most of the time I run into excessive spatter it is usually do to changes made to the torch angles for the automated systems anyway. I have all my parameters lock out. There are some products out there that are supposed to help reduce spatter (Like Spattershield system) but I havent tryed them...maybe they work maybe not.
regards
kam
Parent - By Hi-lex Date 02-26-2004 21:00
The rail thickness is 1.2mm, the bracket thickness is 1.6mm. There are three projection beads on the bracket. It is an automated projection welding process on a 150Kva welder. Thank you for your suggestions.
Parent - By dee (***) Date 02-26-2004 23:27
Adjustment of power supply, wire diameter, and gas combine to provide extreme flexibility in GMAW process.
Your adjustments were restricted only to power supply settings?
Mask the slide with a piece of sheet-metal, copper strip, etc,
How about more specifics on the projection design?
I believe this problem was being interpreted as a GMAW process issue- projection welding is rather like a spot-weld process; remove the Zn at the weld and re-evaluate the adjustments which had tested unsatisfactory before scrapping out any parts. Early post by JW about ZN is accurate- it causes weld issues.
Parent - - By CHGuilford (****) Date 02-27-2004 14:19
Is there any way to mask off the weld areas so that galvanizing doesn't bond to those locations? Epoxy paint will prevent zinc from bonding to the steel but I don't know if that would work for you. It sounds like you are working with pre-galvanized materials?
Other than taking another look at your welding parameters and seeing if you could make changes you might have missed (drag or push angle, electrode stick-out, shielding gasses, etc.) I would try an anti-spatter spray or something like that.
Chet Guilford
Parent - By jwright650 (*****) Date 03-01-2004 01:16
Hi Chet,
I gather from his post that they buy the material already galvanized and on a coil. They are stamping out the parts and trying to projection weld the parts together. I have no practical experience with projection welds, so I've just been watching to see replies.
John Wright
Parent - - By brande (***) Date 02-29-2004 07:14
Splatter is not acceptable in any welding situation. It should be easily cured with proper welding parameters. While the zinc coating on galvanised may cause some spatter, due to the low zinc melting point-proper adjustment of welding voltage and wire speed (I'm assuming mig here) should give you a relatively splatter free zone.
Also, if you are migging these joints, be sure to use an E70S-3 wire instead of the standard S-6. You will have fewer metallurgical problems like cracking and the like.
Any questions, email direct.
Good Luck
brande
Parent - - By dee (***) Date 02-29-2004 21:13
Guys!,
Hi-Lex specified he was projection welding the parts. It's a [resistance] spot weld techinque. It is not a wirefeed process.
Parent - - By dee (***) Date 03-01-2004 00:35
Hi,
I am thinking the parameters are wrong. I dont know much about the process, but I am not totally clueless. I was however waiting for someone with some actual credentials in the process to speak up- the thread has been pretty badly confused by this point.
Pressure must be distributed equally between all projections; I really dont know that the pressure properly distributed or the time was sufficient in the adjustments that were made back when the welders were trying to overcome the trouble. There should not be a spatter problem, and perhaps the current is flowing before the pressure is fully applied or the machine is otherwise out of kilter. It wants verification first.
If all else fails the wrong way to control the problem is to redesign the projection- building a spatter shield right into the boss (a bulls-eye rather than a simple dimple)
(eventually the spatter debris will fall out and cause service problems down the track)
Good luck Hi, and try the repost. Fellows who know resistance processes are also probably thinking this is a GMAW issue.
d
Parent - - By jwright650 (*****) Date 03-01-2004 01:12
Hi D,
After I found out more about what he was doing, I kept quiet. Projection welds are a different animal than we are used to. I've done a little reading on it but no experience.
John Wright
Parent - By dee (***) Date 03-01-2004 07:43
JW,
I had a buddy who used to do resistance welding of various kinds for fabricators around here. As I said I'm not totally clueless, but I was sure glad Bmaas picked up, not having what I would call experience either. I was concerned that Hi might think we were all inhaling too many weld fumes or something.
regards
d
Parent - - By bmaas1 (***) Date 03-01-2004 04:12
This is information that I had from a seminar I attended a while back.
I believe your problem might be in your slope adjustments.
SLOPE CONTROL, definition and info for RSW
Slope control is a form of automatic heat control. Up Slope is in increasing heat and Down Slope is a decreasing heat. The timing set for the slope functions determines the steepness of the rise or fall of the heat. The dial timing indicates the number of cycles to rise from minimum to maximum heat or visa versa. The trace of the rise or fall of the RMS voltage is a logorithmic curve which when translated to heat is an almost straight line change.
Slope control provides numerous little understood attributes for welding of many different metals and various different welding machines. The use of up slope takes the spit out of the start of welding current flow. Whether the spit would be caused by not enough pressure, oily or scaly stock, misfit parts or too small an electrode contact area, the chances are that no spit will occur. The successive half cycles of increasing voltage and current will gradually heat the stock, seat the electrode into the material, hotforge the misfit seperated parts together and complete a sound weld which otherwise might have been a hole burned through the parts. Sound spot welding never throws sparks. Sparks are molten metal which should have been part of the weld nugget.
Up slope contol was originally designed and built for cross wire welding where the wires cross at right angles and have just point contact at the start of the welding. Unless a very low power is used the wires will flash when the welding begins. The up slope control prevents this flash and it also increases the welding current progressively as the contact area grows. The net result is a good sound weld made quickly with a smooth fillet of metal around the weld area instead of a ragged rough edge as is often the casewithout slope control. Cross wire welding is classed as natural projection welding. The welds are usually made in multiple groups.
Up slope control is indicated for normal projection welding. It prevents the splattering of the material of the projections both from electrical flash at the start of the weld and by mechanical impact when the welding ram catches up to the heating of the projections. Unless the material of the projections is maintained in the proper place to form weld nuggets, the planned strength of the welded assembly may be destroyed.
Up and Down slope is widely used to prevent embrittlement caused by too rapidly cooling of many low alloy steels and the lower carbon steels, 1025 and lower. Down slope will not prevent embrittlement of the higher carbon steels. This group requires the use of quench and temper.
Hope this helps,
Brian J. Maas
Parent - - By Hi-lex Date 03-01-2004 15:48
Everyone,
Thank you for the information. I have forwarded the relevant pieces on to my plant. If you come accross other useful info, please post it.
Thanks,
Hi (she, not he)
Parent - By bmaas1 (***) Date 03-01-2004 16:00
Let us know how it goes.
Brian J.Maas
Parent - - By jwright650 (*****) Date 03-01-2004 16:49
Sorry for the mis-gender. It's not the first time and probably won't be the last time we thought a she was a he or visa-versa. Assumptions get us in trouble sometimes, sorry.
Hope no harm was done,
John Wright :)
Parent - - By Hi-lex Date 03-01-2004 17:00
JW,
No problem.
Parent - By norris Date 03-01-2004 17:42
It really sounds like you have
a problem with your pressure setting.
I would start there.
If that does not solve your problem
you can also look at your machine setup.
I do alot of spot and projection welding
and these are two areas I check first.
Try increasing your pressure.
Good Luck
Parent - By dee (***) Date 03-01-2004 18:49
Hi, Hi,
I have the same trouble from time to time, being a he not a she,
d
