I've only soldered and brazed copper using oxy/acet. Copper is funny about welding from what I understand, it takes alot of preheat. Gotta get it clean, no oxidation, use some type of flux. Is there a reason why brazing or soldering won't work for your project? Or is this just a "see if I can weld sheet copper" project? What is your joint design? Can the use of an arc process (possibly GTAW) work in your situation rather than oxy/acet?
Maybe others that have welded copper can help.
John Wright
