Here is some information on T-1.
http://intlsteel.com/PDFs/products/t1.pdf
If you want a full strength butt joint, 11018M would be a good choice. 7018 is much weaker than T-1 plate. If you are doing fillet welds, an oversized 7018 joint would probably work ok. Preheat would be required for T-1, but without knowing for sure what your base metal is, it is hard to know for sure what to preheat to.
