Up Topic Welding Industry / General Welding Discussion / Source for 6" O.D. Steel pipe
- - By wnc (*) Date 03-15-2004 00:08
I've looked all over hell and half of Georgia for a 6" OD diameter steel pipe for use on a woodstove project I have going and I can't find anything anywhere.Does anyone know of a common source for pipe this size?
Thanks in advance
Parent - By pipewelder_1999 (****) Date 03-15-2004 02:20
6" Pipe is actually 6-5/8" OD. If you want a 6" OD you will need to specify tube by OD and wall thickness.
Hope t his helps
G Austin
Parent - By GRoberts (***) Date 03-15-2004 17:29
Are you looking for flue pipe? That can normally be gotten at a building supply store.
Parent - By billvanderhoof (****) Date 03-16-2004 06:09
I assume this is for the spigot that the stovepipe hooks up to. I've always liked to hook the pipes up "backwards" that is with the small ends toward the stove. Then the condensate runs back into the stove instead of dripping out on the floor. If you agree then you would want 6" id. Most contractors that install gas piping in the street will have some that they have removed from time to time. Usually cheap.
Bill
