Dear Sir,
We have to manufacture a cooling jacket made of pipe of the following chemistry and channels, sq rods and plates welded on this pipe are of ordinary mild steel. Chemistry of the pipe material is
C: .15(max), Mn: 1.6, Cr:0.5-0.8 , Al: 0.40 and S & P: 0.025 max
Pls advise the filler metal reqd for welding this pipe and this pipe and mild steel. Only test to be conducted on this cooling jacket is Hydraulic test at 6 kg/cm2
Mukesh Agarwal
