Hi Bill A!
Thanks for your input...
After I asked the question about using 321 or 347, I looked up the tensile and yield strengths between them, and with what I think is a 310 grade stainless (the percentages of Cr and Ni are very close) that H. Chang is using and you're correct!!! In fact both the tensile & yield strengths would be lower in the weld when compared to this 310 grade base or parent metal at elevated temps... I could'nt find anything on 312 but, I'll look again... I did however notice that there's Cb in the stainless base metal so, I initially thought that the 347 would be helpful in this situation...
I'm just guessing H. Chang but, Kobelco - a Japanese filler metal & welding products manufacturer may also provide some insight on choosing the optimal filler metal composition for this 310 grade of stainless... The link to their website is on the homepage for the AWS website on the top of the page. Also check out this .pdf from Allegheny Ludlum: http://www.alleghenyludlum.com/ludlum/Documents/309_310.pdf
I did some surfing and I found a very similar composition of this grade of 310 stainless in the British Stainless Steel Association.
The trade name is "HR3C" which is a sulphurizing resistant grade from Sumitomo Metal Industries, sound familiar?
The most impressive site I found was the Sandvik website... they even had Delong, Schaffler and WRC ferrite diagrams for a variety of stainless steel catagories with the formulas for the respective Cr & Ni equivalents!!! Check it out: http://www.steel.sandvik.com/techdata/index.html
http://www.smt.sandvik.com/ When you get there, scroll down on the welding products page where the page shows a ss grades chart w/chem comps... look for for special purpose grades, then look for their (Sandvik) number designations and the AWS ER equivalents.
Compare the chem comps for the 312 (29.9) and the 310 (25.20.C), then scroll down to the special purpose grades and look for grades 25.20.L and right underneath, grade 25.22.2.LMn (310LMo) which has some N in it also... At first, it looks like a match but,wait a minute!!!
In the column to left of the page, click "welding products", then click "wire electrodes and filler wire/rods", then click "properties and applications"... when the chart on the right appears, scroll down to each of the grades that has a dissimilar metals (Austenitic to Carbon stl.) application recommendation... read each one for 309L
(24.13.L & 23 12 L), 24.13.LHF (another 309L),
309Si (24.13.Si & 22 12 H), 309LMo (22.15.3.L & 23 12 2 L) and
312 (29.9)... finally, scroll down to the last grade, Sanicro 72HP (NiCr-3).
The correct choice is in one of those grades that best fits your application!!!
As far as the embrittlement or solidification cracking potential goes,
the delta ferrite limits are between 4 to 10 % generally speaking of course... Hey DGXL! thanks for supporting what I also suggested to H. Chang about the weaving technique!!!
In any event, I appreciate your responses and one thing is for sure, I'm always learning something new from someone in this forum...
SSBN727 Run Silent... Run deep!!!
