Hi Larry -
One specification for Hospital Piping for Oxygen os AWS D10.13-95, Recommended Practice for the Brazing of Copper Pipe and Tubing for Medical Gas Systems. This is available from Global Engineering Documents, CO, 800-854-7179. All AWS documents are sold through Global.
Also the Brazing Handbook 4th Edition is a text book on brazing and is available from Global.
Another source for the information on supply lines for medical gases is NFPA, National Fire Protection Association, order department, 800-344-3555, NFPA 99C, Gas and Vacuum Systems. The full edition from which the NFPA 99C is an excerpt is NFPA 99, Health care Facilities. Both of these publications call out AWS B2.2 Standard for Brazing Procedure and Performance Qualification and the ASME Boiler code, Section ASME IX. Brazing Filler Metals should comply with AWS A5.8, Filler Metals for brazing and Braze Welding.
At Present I do not kNow of a testing laboratory who Certifies the Brazed Joint Specimens. If you find such a source please let me know.
Bob Peaslee, 248-585-6400 x240
