Here's your product.
“THE WONDER ALLOY”
A uniquely versatile very low heat alloy that joins white and pot metals with ease. Particularly suited for
soldering all types of dissimilar metals i.e.: copper to aluminum, brass to steel, zinc to stainless etc…
IDENTIFICATION: Silver Colored Soft Wire
APPLICATION: Torch or Soldering Iron
CRONABRAZE 53 SUPERIOR ADVANTAGES:
• TOTALLY LEAD AND CADMIUM FREE
• EXTREMELY LOW MELTING POINT
• MORE THAN TWICE THE STRENGTH OF ORDINARY SOLDER
• THIN FLOWING, SAFE AND NON TOXIC
TECHNICAL INFORMATION:
TENSILE STRENGTH: 17,500 PSI (121 MPa)
TEMPERATURE: 360°F (182°C)
OPERATING PROCEDURES:
Base metal must supply heat as a direct flame is unworkable. A carburizing flame should be used.
Flux is required for all applications where good bondability is desired.
APPLICATIONS:
• CHROME PLATED ZINC DIE CASTINGS
• AIR CONDITIONING AND REFRIGERATION UNITS
• DISSIMILAR METALS SOLDERING
• HEATERS, RADIATORS AND EXCHANGERS
• ALUMINUM TO COPPER TUBING
CRONASOLV ™ F53 flux is required
CONFIDENTIAL MATERIAL, REPRODUCTION, IN WHOLE OR IN PART, PROHIBITED Printed in U. S. A. (Rev. 7/ 00)
PART NO.
CW1842
CW1017
SIZE
1/16 Spooled
1/8 x 18
WE 9 Corporate, Research & Distribution Headquarters: 6510 Northpark Blvd., Charlotte, North Carolina 28216-2367 / 800-843-0763
CRONATRON WELDING SYSTEMS, INC.
CRONABRAZE ™ 53
Return to Index
