Up Topic Welding Industry / Technical Discussions / TIG Welding of Silver
- - By Gordie Date 04-25-2004 13:47
For thin sections is a complete Argon atmosphere required to prevent the non-welded surfaces from oxidizing?
Best regards,
Gordie
Austin, TX
Parent - - By Gordie Date 05-05-2004 19:35
Surprised that nobody can assist us here............
Parent - By jwright650 (*****) Date 05-05-2004 20:41
Sorry Gordie,
If I had any experience at all with Silver, I would help if I could.
John Wright
Parent - By swnorris (****) Date 05-05-2004 21:28
Hi Gordie,
I don't know if this helps in any way, but in Volume 4 of the Welding Handbook published by the AWS, "Metals and Their Weldability", all it says is that argon or helium is effective in preventing oxygen contamination of the molten weld pool during arc welding. It also has a table of physical properties, and briefly discusses different types of fusion welding processes such as GMAW, GTAW, OFW, and EBW. It also briefly discusses brazing, soldering, projection welding, and the difficulty of resistance welding.
