Hi gunmonk,
From the dimensions you provided, it sounds like what you have is either a 65 or 70 pounds per foot A.S.C.E. rail. I think the 70# is no longer in production. The 65# is 4 7/16" tall and 2 13/32 wide at the rail, and 70# is 4 5/8" tall and 2 7/16"wide at the rail, both weights conform to ASTM A759. I don't have access to the ASTM Specification, but the rail is probably a high carbon steel. It sounds like you're planning to use some sort of oxyfuel gas welding process, which I don't know too much about, so I wouldn't know how much it differs from stick or wire welding in terms of preheat and postheat procedures, but for stick or wire welding on such an application, preheat temperatures of around 800-1000 degrees F are necessary to prevent cracking, and postheat is needed for stress relief at around the same temperature as the preheat, and allowed to cool naturally. Mckay Hardalloy 118 rods or Railend 932-0 rods and wire are two good filler metals. Maybe they produce a filler metal for your application.
Hi Gunmonk,
I've seen alot of railway welds done by thermo-welding. It looks like a mini-blast furnace that you stick over the join. Its strong, produces good results and looks cool when performing it!
Pascal.
