I have to say that RJohnson has a good point about the height of your ceilings. Our shop is old and has been added onto over the years and we have found that the overhead cranes running on an over the rail configuration lends to higher hook working heights. For instance, if you had something on the bed of a trailer and the trailer is over four feet above the shop floor, that takes 4 ft off of your working room right there, and if the peice on the trailer is 5ft tall, there goes 9 ft of working height. One side of our shop had under hung cranes and the ceiling is low....terrible for working structural steel and loading trailers. The rest of the shop has higher ceilings and works much better.
Also note that welding smoke will rise above the welder and higher ceilings will help dilute those fumes to acceptable levels along with some ventilation from a powered ridge vent.
John Wright
