I would like to recommend to preheat at max. interpass temperature.
If you want to preheat above max. interpass temperature which was approved during procedure qualification test, you may have a weldment with low toughness and low strength due to slow cooling. Separate procedure qualification test will tell you possible highest preheat temperature.
