It is probably titanium, grade Ti - 6 Al - 4 V (Ti64) in the annealed condition. RMI is a titanium producer in the United States. Strike an arc on it and the bead should look shiny (keep the gas on it till it cools)
and the backside will likely turn white. Look in a handbook for more information on it, there is a lot of information out there.
Regards.
MIL means a "military" standard, i.e., one that's been issued by the U.S. armed forces. The one you mention in your question shouldn't be a military secret and must be available in any technical library (isn't there an engineering school near you?) or directly from the armed forces of the U.S.A. (isn't there a military dependency near you?).
Another source should be the manufacturer, i.e., the RMI company, whose address I don't know buy shouldn't be that difficult to find, especially if you're in the U.S.
