When performing a Welder Performance Qualification Test for Arc spot welds AWS D1.3-98 list the qualified thickness range as (Thickness tested) in Table 4.2. Paragraph 4.8.1.2 confirms this.
The essential variables for the PQR Table 4.3 (9d) allow a range for 16 gage or thinner if the test is performed on 18 gage sheet.
Since welding arc spot welds is not prequalified does this mean it requires that welders performing deck welds need to qualify for each thickness with a WPS and supporting PQR and WPQT for each. If so if the base material changes thickness does this also require a new WPS.
I also notice that the WPS and PQR forms do not have a place for base material coating specifically. Does this imply that if welding painted joist that it doesn’t matter the coating thickness or that another set of WPS, PQR, WPQT’s need to be performed for each combination of welds made with differing coating, sheet thickness’, and base material thickness’.
If so that would mean to weld down the roof of the average warehouse with three different thicknesses of deck, three different thickness joist, with different coating thickness’ and lap joints would require - 18 different WPS, PQR and WPQT’s.
Please help I can’t expect this but would like to follow the code if possible
