The optimum ferrite greatly depends on the type of service. If at elevated or cold temperatures, low ferrite is desirable. High ferrite can help resist Stress corrosion cracking in marginal situations. You need to find out what is desirable for your particular situation, as there will be no general answer applicable to all situations. The 5% ferrite mentioned in the post by rodofgod is a ballpark figure for weldability (hot cracking resistance), not necessarily corrosion resistance. To resist hot cracking, the weld metal needs to solidify as primary Ferrite instead of primary austenite. (See the 1992 WRC diagram)
