Up Topic Welding Industry / Technical Discussions / Ni60 overlay on A36
- - By wonderweld Date 06-07-2004 23:29
I'm doing an overlay of Ni60 GMAW on A36 material. My question is, am I "required" to use Ni61 as my first layer?
Parent - - By Niekie3 (***) Date 06-10-2004 17:42
Hi
Do you mean Monel 60? and Nickel 61? If you do, then you would not normally require a buttering layer of Ni61. Monel 60 will give a suitable first layer, as long as the dilution of the base metal into the filler does not exceed about 60%. (This is quite high. For overlays, the dilution is typically around 30 - 50%, depending on the process and parameters used. With some low dilution processes and parameters, dilutions as low as 10% can be achieved.)
Hope this helps.
Niekie Jooste
Fabristruct Solutions
Parent - - By wonderweld Date 06-12-2004 11:21
Niekie, You are correct, Monel 60. I'm doing multiple layers to achieve
.312" overlay thickness which will be machined back to .187" thickness(NAVY job).Time was a problem as well as cost. At $20/ lb I need to use approx. 8 30 lb. rolls of 60. Thank you for your insight and I believe I will go with 60 alone.
Parent - By ssbn727 (*****) Date 06-13-2004 20:57
Hi Wonderweld!
Not to put a damper on your party but, If the Ni 61 is a contract requirement and is specified then, the Navy (if it's the USN?) may not accept what you give them. Just a thought!
SSBN727 Run Silent... Run Deep!!!
