Up Topic Welding Industry / General Welding Discussion / welding cast iron parts
- - By bzzzzzzzzzz (**) Date 06-07-2004 23:43
OK, so what is the general rule of thumb here? Let's say this is a part which is not subject to thermal shock of any kind. Just needs to operate some gismo and have near the original strength of the casting before it broke. Let's also assume the part is less than 1/4" thick. What is the best process and technique to use? I'm just asking about cast iron here.
Parent - By pjseaman (**) Date 06-08-2004 03:22
High Nickel rod maybe NI55, or NI99 in stick process, but I will admit they are very expensive, but Quality is what your after- right! I recently bought a 1# container and it was around $30. I've mated multiple different materials with NI99- cast-hardened studs-and forged axles on a race car and not a single failure in 15 races, with 12 wins so it wasn't a trailer queen! This is 1 case but for less rigid requirements NI55 would be good.
My $.02 worth,
pjseaman
Parent - - By billvanderhoof (****) Date 06-08-2004 06:25
In addition to the nickel based rods-
Brazing works well. If you get everything hot enough you can usually sweat the filler into the joint. Braze is about as strong as cast and if it will sweat in you can make a repair that is almost invisible.
I have had good luck with small things where it is possible to heat the whole part by preheating to red heat, mig welding with regular e70 wire and cooling slowly.
Bill
Parent - By swnorris (****) Date 06-08-2004 13:38
Hi,
Rods in the ESt group (covered electrode with steel core wire) are generally used where lowest cost or maximum strength are desirable, and a non-machineable bead is acceptable. Rods in the ENi group (covered electrode with nickel base core wire) provide a soft, ductile, machinable bead and fusion zone with a slight sacrifice in strength, an increase in cost, and in cases of larger castings can be used without preheat, but only if light loads are applied to the casting. Rods in the Eci group (covered electrode with cast iron core wire) provides a weld metal most similar to that of the base metal of the casting, but shouldn’t be used unless the casting can be moved to a furnace and/or subjected to an extremely high (red hot) preheat.
Surface preparation should consist of removing casting skin and foreign material from joint surfaces and adjacent areas, and if the casting has become impregnated with oil or grease, remove it with a solvent or by steam cleaning. If the casting has become impregnated with a plastic or glass sealer, it probably can’t be repaired because the sealer will produce gross porosity or inhibit bonding.
Amp ranges for 1/8" diameter rods in the ESt group are around 80-100, with DCRP or AC. Amp ranges for 1/8" diameter rods in the ENi group are around 60-110 with DCRP, and 65-120 with AC. Amp ranges for 1/8” diameter rods in the ECi group are around 150-175 with DCRP or AC. Practically the same welding procedures are used for both gray iron and malleable iron. The prime difference is the need to heat treat malleable iron to restore its properties after welding.
When welding gray and malleable irons, the area adjacent to the weld is raised above the critical temperature, about 1450 degrees F. The mass of the casting around the weld tends to draw heat from the weld area rapidly. If this cooling of the heat affected zone and the weld is more rapid than it was when the casting was originally made, a highly brittle, crack sensitive zone develops. Preheating the casting to slow the cooling rate will help prevent the iron from rapidly absorbing heat from the weld area. Some castings can't be preheated, so when selecting welding techniques and electrodes, be sure take into account whether or not your casting can be preheated. If your casting is small, it can be welded satisfactorily without preheat, although preheat usually improves the toughness of the weld. Slow cooling is always essential. If you choose not to preheat, a two-pass weld can be made if a soft fusion zone is what you're looking to achieve. The first pass serves as a preheating for the second pass, which tends to slow the cooling and produce an annealing that makes a softer, more machinable fusion zone.
This link may be helpful to you:
http://www.twi.co.uk/j32k/protected/band_3/jk25.html
Parent - - By phred Date 08-29-2004 10:09
I weld cast iron with cast iron filler rod, flux for cast iron, and a torch. When it is done, it is all cast iron. It works great.
Parent - By harleyhitman (**) Date 01-15-2005 03:20
Cronatron 211
“THE CAST IRON PROBLEM SOLVER”
Unquestionably the final answer to the most difficult cast iron repair welding. This highly sophisticated
alloy allows repairs that were previously impossible.
IDENTIFICATION: Printed Electrode, TIG Flagged One End
APPLICATION: AC or DC Reverse Polarity
CRONACAST 211 SUPERIOR ADVANTAGES:
• HIGH TENSILE WELDS IN EVERY TYPE OF CAST IRON, INCLUDING GREY AND
MEEHANITE; ALSO PRODUCES EXCELLENT STEEL TO CAST IRON WELDS
• CRONAMIG 211 IS FULLY MACHINABLE AND HAS A HIGH ELONGATION
FACTOR WHICH POSITIVELY PREVENTS CRACKING
• PASS OVER PASS WELDING WITHOUT SLAG REMOVAL BETWEEN PASSES
• ALL POSITION WELDING CAN BE DONE WITH CRONAMIG 211 WITH NO
DISMANTLING OF EQUIPMENT PARTS
TECHNICAL INFORMATION:
TENSILE STRENGTH: 70,000 PSI (483 MPa)
BRINELL HARDNESS: 185-240
OPERATING PROCEDURES:
Use AC or DC reverse polarity. Generally, where a narrow, thin
bead is desired a straight polarity application is suggested.
APPLICATIONS:
• GEAR TEETH • PUMP IMPELLERS
• SPROCKETS • CAST IRON TO STEEL
• PUMP HOUSINGS • CYLINDER BLOCKS AND HEADS
• BEARING HOUSINGS • TRANSMISSION CASES
• TURBINES • HYDRAULIC PRESS RAMS
CONFIDENTIAL MATERIAL, REPRODUCTION, IN WHOLE OR IN PART, PROHIBITED Printed in U. S. A. (Rev. 7/ 02)
PART
NO.
CW1035
CW1034
CW1033
CW1032
ELECTRODE
SIZE
3/32
1/8
5/32
3/16
AMPERAGE
55-95
75-110
120-150
140-175
COMBO PAC . . . . . . . . CW1725
PART NO.
CW1901
CW1902
CW1903
SIZES
CRONATIG™ 211T
1/16 x 36
3/32 x 36
1/8 x 36
CRONATRON WELDING SYSTEMS, INC.
CRONACAST ™ 211
CRONAMIG 211M-FC CRONATIG ™ 211T
PART NO.
CW2065
CW2066
CW2057
CW2058
CW2059
SIZES
CRONAMIG™ 211M-FC
.035 x 10 lbs.
.035 x 33 lbs.
.045 x 10 lbs.
.045 x 33 lbs.
.062 x 33 lbs.
WE 14 Corporate, Research & Distribution Hdqrs: 6510 Northpark Blvd. Charlotte, NC 28216-2367/ 800-843-0763/ www.cronatronwelding.com
Return to Index
