After using all the bore welders on the market, the best one is clearly the BOA-308i by Bore Repair Systems, Inc. If reliability, simplicity and easy setup in the field is what you are after, call them at 1-800-650-1005. They also have integrated boring bars and bore sizers, so you can get everything in one stop. http://www.borerepair.com
