Hi LL,
I agree with what Chet is saying about the welding, and will add that if CVN testing is required, in order to perform CVN testing, you have to remove test specimens from the weldments. As far as welds go, you can only perform the CVN test on test pieces welded in the exact same conditions to represent the same properties finally available in the finished bridge, with the exception of the curves, not specimens from the actual finished product.
I don't know what design you're using on the bridge, and I am definitely not an engineer, but if there's a single tube arch on each side, and the splice is at mid-span, it seems to me that the weld on the top of the tube would be in compression and the weld on the bottom would be in tension, and subjected to tensile stresses. I say this because tensile stress is the stress that is applied to an object by either pulling on it or attempting to stretch it, which would seem to apply to the bottom weld, and compression is the opposite, which would seem to apply more to the top weld, as the compression forces are trying to compact or crush the weld. As for the other two sides, it seems that it would be a gradual shift from compressive to tensile stresses, because it seems that the forces on the top half of the weld would be trying to compress it, and the forces on the bottom half of the weld would be trying to pull it apart.
Just curious here. Is it a requirement in the specifications or bid documents that the fabricator be an AISC certified company in Simple (Sbr) or Major (Mbr) Steel Bridges? I think that if Fracture Critical members are to be produced in accordance with AAASHTO or AREMA codes the fabricator must also have the (F) Fracture Critical Member Endorsement.
Here's a link that might be of use to you if you don't already have it:
https://www.transportation.org/download/SBFQC-1_AASHTO.pdf
It's to the Steel Bridge Collaboration Guide Specification, which is a guide specification for bridge fabrication, quality control, and quality assurance. It is an AASHTO/NSBA publication with loads of information.
I apoligize, I was out of town and could not give your question my full effort. I mean this with all due respect, but you really should do some more research on the subject. But I will give you a nutshell explanation.
CVN testing is used to determine the low temperature impact strength of the steel being tested. It gives a value relative to the material that is being tested to see how it can be expected to perform in comparison to other materials. This gives a relative indication as to how the steel will behave at depressed temperatures under an impact loading.
The test itself consists of machining specimans from a sample of the steel. Commonly, 3 specimens are made for each test. The specimens are a certain size (usually 10 mm X 10 mm x approx. 75mm) and have a precisely shaped notch cut into them. The specimens are cooled to a certain temperature, depending on the Zone specified. Specimens are placed in a (calibrated & certified) machine, a weighted pendulum swings and breaks them, and energy absorbed by the specimen is recorded; usually in foot/ lbs for the USA.
Usually specimens are extracted parallel to the grain, or rolling direction, of the steel. Some job specs require some testing done transverse to the grain, which is steel's weakest axis (much like the grain within a piece of wood)
Zone 2 testing requires 15 ft/lbs avg min at +40F for non FC materials (T2) and 25 ft/lbs avg min at +40F for fracture critical (F2). You will see there are T and F test designators. Zones correspond to geographic areas of the steel's end use (1 is for warmer areas such as Florida, 2 is used in most of USA, and 3 is for arctic conditions).
There is also "H" frequency where one CVN test represents all material produced from the steel heat number, and "P" frequency where each plate or batch of shapes is tested. Fracture critical work usually requires "P" frequency.
Welds are tested in a similar way, specimens are extracted from a test plate such that the notch will be located within weld itself. CVN test results for welds usually require a colder test temperature. Fracture critical, zone 2 is 25 ft/lbs avg min @ -25F (or somewhere around there, I don't have my D1.5 handy).
Naturally, all this is destructive testing.
It is not useful for testing actual production welds or production materials.
CVN tests (and several other tests) are done on weld test plates to prove the filler metal/base metal combination works when welded according to test parameters. As long as the testing was done, there is no need to do it again. QA/QC oversight makes sure the work is welded correctly.
Materials are usually purchased to comply with CVN specifications. The mill will cut off a piece of material and perform CVN testing on it. Results are then given to the customer. Sometimes a vendor or a fabricator will cut off a sample for testing when the original mill order did not specify otherwise. That is usually accepted by the owner (assuming satisfactory test results).
Rectangular HSS steel is formed from plate and welded together. CVN specimens can be easily cut from a piece of stock, remember, 10mm X 10mm. When the sample is too thin for full sized CVN specimens, sub-sized specimens are used.
Mills that produce HSS obtain their raw materials from plate producing mills. If requested, the HSS mill can usually produce a mill test report for the plate they used. So an A500 Grade B could have started as A572 Grade 50.
Hopefully this clears up what you asked. I would not ask for production welds to be CVN tested. Instead, I would require that FC welding be qualified by testing per AWS D1.5 section 12. I would specify that materials must meet F2 CVN requirements (assuming you are not in Alaska).
I would require MT (magnectic particle) testing of the root passes of full penetration welds, and UT and/or RT testing of the completed full pen welds. MT testing of fillet weld (usually 10% of each weld or 12" minimum) is a good idea. 100% visual is already required if D1.5 is invoked.
But also important, please realize, the "FC" designation is very over used when the actual conditions are not fully understood. FC fabrication is much more expensive and time consuming, and doesn't automatically mean the product will be better than "regular" fabrication would be. That's why I asked if you situation is a true FC condition. You might save a lot of time and money and still have a very satisfactory bridge that will last a long time.
Chet Guilford
