Thanks Scott. Having said that, there's no reason I can think of other than cost that would "prohibit" use of ER316L for welding 304, depending on local specifications, naturally.
By -
Date 08-20-2005 16:21
swnorris,
Unless I'm missing something here, I respectfully disagree with the FCAW part of your answer. According to ANSI/AWS A5.22, 1995 edition,
"Specification for Stainless Steel Electrodes for Flux Cored Arc Welding and Stainless Steel Flux Cored Rods for Gas Tungsten Arc Welding", Table 2 lists the recommended gas shielding for the FCAW processes. I agree that the "1" designating the gas shielding is for CO2, but there is no "2" designation for FCAW listed in the Code book, only 1,3,4,and 5. The "3" designation is a non-shielding FCAW, the "4" designation is for 75-80% Ar and remainder CO2, and the "5" designation is 100% argon for the GTAW process. I realize what the Welding Handbook says, but the Code Book for FCAW differs from that. In A2.3.3 of the Code Book it states,"Following the position indicator and the dash, are the numerals "1", "3", "4", or "5", or the letter "G". The Code Book makes no mention of a "2" designation. except to say, "In ANSI/AWS A5.22-80, stainless steel classifications for 98%Ar-2%CO2 gas shielding existed (EXXXT-2). The combination of a slag covering and this shielding gas has been found to be inappropriate for flux cored arc welding and the EXXXT-2 Classification has therefore been deleted from A5.22-95." Respectfully, 98%Ar-2%Co2 is definitely not recommended for FCAW welding of stainless steel. Also, the "-1" and "-4" gas designation are dual classified.
Chuck
