Up Topic Welding Industry / General Welding Discussion / little TIG inverters @ 230V single phase
- - By Scott_V Date 06-27-2004 19:37
Uhm,
Went through a lot of work researching this so wanted to put it in an on-line archive. Just a list of current draws and outputs in TIG mode and using 230V single phase for the lightweight inverter welders that I'm considering. Figure there are others with 30amp circuits that can use the info:
Miller Dynasty 200 DX 45lbs (also 3 phase capable and 115V single phase capable)
150amps 16V 60%duty 230_single_phase 15.8amps-in
max draw - same as above
http://www.millerwelds.com/pdf/spec_sheets/AD4-8.pdf
Lincoln Invertec V205-T 38lbs (also single phase 115V capaple)
170amps 16V 60%duty 230_single_phase 18amps-in
max draw - 30amp_in@200amps_out 18V
http://content.lincolnelectric.com/pdfs/products/literature/e3110.pdf
Thermal Arc 185TSW 42lbs (230 single phase only)
130amps 15V 60%duty 230_single_phase ? amps_in
max draw - 38amps_in@185amps_out 17.4V
http://www.thermadyne.com/tai/literature/pdfs/service/430429_503.pdf
Parent - By 340mag Date 06-27-2004 22:19
http://www.htpweld.com/product_page/tig_welder/tig201.html
Specifications
Input Voltage 230 volts +/- 20%
Input Amperage 30 amps
Output Amperage 4 to 200 amps
Duty Cycle 35% @ 200 amps
60% @ 160 amps
100% @ 125 amps
No Load Voltage 65 Volts
Arc Voltage 10 to 18 volts
Torch Length and Type 17 Series 25' Long
Foot Pedal Length 25'
Slope Down 0.1 to 10 sec
Pre-Gas Flow 0.5 Sec
Post Gas Flow 2 to 20 sec
Final Current 0 to 99 amps
DC Pulsing Frequency 0.4 to 300 Hz
AC Pulsing Frequency 0.4 to 2 Hz
Pulsing Duty Cycle 50%
Pulsing Base Current 25%
AC Frequency 20 to 200 Hz
Balance Control 10 to 90%
http://www.daytonamig.com/tig.htm
Heliarc 161 AC/DC
Specifications
Primary Input Voltage/Phase 208/230Vac, 1ph, 50/60 Hz
Primary Input Current @ Rated Load 30/27 Amps
Efficiency 83%
Power Factor .81
TIG Duty Cycle & Rated Output 40% - 160 amps @ 16.4 v
STICK Duty Cycle & Rated Output 35% - 160 amps @ 26.0 v
Open Circuit Voltage (max) 50 v
Net Weight 28.7 lbs(13 kg)
W x L x H(both models).............................8.0in.(200mm) x 14.4in.(360mm) x 16.4in.(410mm)
heres two more choices
Parent - - By brande (***) Date 07-03-2004 05:11
Always check the watts. Watts are volts x amps. Watts are also where the work is done. Watts are heat, very important in welding ;-)
That said-the major manufacturers went through a marketing thing a while back.
They would lower voltage slightly, or not slightly, to increase amp rating, duty cycle, etc. It was basically a marketing thing-no, it was definitely a marketing thing.
Buyer be aware-do your homework!!
Any questions-email me direct.
Good Luck
brande
Parent - - By Brand X (*) Date 07-03-2004 18:58
I used to be Scott V myself but it looks like there is another one out there. It's ok though because the second one seems much brighter.
Parent - - By Brand X (*) Date 07-03-2004 19:00
My friend Aaron had the Thermal 185 and he was drawing less then 30 amps at 199 amps output.
Parent - By Scott_V Date 07-08-2004 15:24
I found a site comparing welders and it listed the 185tsw only pulling 30 amps at full output, but the owners manual says 38 amps.
That's good news for me because I ordered a 185tsw and was worrying about tripping circuit breakers.
Parent - By Scott_V Date 07-08-2004 15:28
I used to be ScottV but that was already taken.
You're right he does seem brighter :-)
(the first one, that is)
Parent - - By Scott_V Date 07-08-2004 15:58
Max output watts for TIG mode using 230V input
2400
3600
Thermal Arc 185TSW
3219
ESAB Heliarc 161
2624
HTP Invertig 201
?? (no voltage listed at max output current)
http://www.esabna.com/eu/literature/Arc_Equipment/15-655-E_Heliarc161%20.pdf
Parent - By dseman (*) Date 07-09-2004 04:51
I know you're trying to summarize some info., but your first and last notes I checked for the dynasty 200dx are incorrect. I didn't check the other welders. You have stated that the max wattage output for the welder is 2400watts, which is incorrect. I suspect you derived this from the 150amps,16volt tig spec on single phase 230vac. The unit easily runs to 200amps on single phase and the output voltage can be extrapolated from the other data points (y=mx+b linear equation). I'm not going to take the time to look at the other values, but just thought you might want to recheck your specs. Also, your first post indicating the single phase MAX draw is 15.8amps for the dynasty 200, is also incorrect. 15.8 amps is the draw for 150amps,16volts. If you increase the amperage to 200amps for tig, the input is likely to be about 22-23amps. Stick welding will draw higher input amperages as well.
-dseman
