If you are an individual or a large manufacturer that is struggling with getting CWI qualified, weld inspectors that cannot read weld symbols, interprit weld defects etc... or you just want to be the best, Please write me and state your problem or training needs. I was formaly trained at Macomb College (Welding tech), have worked as a pipefitter/weldor, welding/blueprint instructor/CWI instructor, 3 years at at Signet private test lab, 5 years Nuclear (Bechtel/Daniel Int.) level II/III QA welding inspection. Presently work for the Army Tank/Automotive Command as a QA welding/special process/mechanical/automotive specialist. Relating to any target audiance, from Weldor to Welding Engineers/supervisors is my promise. The 1st consultation is free.
Regards, Dominic
Remember, "The Best Weld is No Weld at all"
