I'm a little confused, the diagram implys thermostat control, the text implys timer control. Still with the wiring diagram you should be able to follow the circuit with a voltmeter and find the fault. Be suspicous of any switch, the fan motor itself, all wiring connections.
Be really careful, 220 volts can hurt you. My father taught me keep one hand in your pocket, then you avoid those hand to hand shocks which have your heart in the middle.
Bill
