I am having trouble getting the weld to look the way I know it can. I know the settings , gas, filler rod are all correct because I watched someone weld with beautiful beads on the exact same parts on my own welding set up.
My TIG welds dont seem to have the "bead" look of half circles overlapping eachother. I generally get a nice consistent weld, but it is more smoothed together, without the defined crescent shaped patterns.
Also, my welds end up being a dark grey color , whereas my friend welds the same parts, and they have a nice "rainbow" look to them, and are clearly not dark grey.
I also get some possible carbon deposits (brown resideu that easily wipes off) as I weld.
What could the possible problems be? I have tried welding with more amperage, less amperage, faster, slower, and I tried different angles with the torch.
Do I have to make the "C" motions with the TIG to get the crescent shapes?
I have a Lincoln 275 amp welder, welding stainless using both 1/16" filler rod and 1/8"
I am welding both sheet metal (0.65") and parts as thick as .25"
Any help or advise would be greatly appreciated.
